Hi everybody,
i’m facing some kind of phenomenon at the moment.
My Apple TV2 won’t be able to connect via ethernet (dhcp nor manual), i not even get a flashing data-link led on my switch/router. If i unplug the ethernet-cable the ATV won’t switch to wifi. My suggestion is a broken ethernet port which thinks that there’s a cable plugged in.
Would it be possible to alter the the seasonpass JB image in a “ethernet allways disabled” or “wifi allways on” state? Then jailbreak the to a wifi-only, but otherwise fully funcional device? Current ios is 5.3
Cheers
