Using the most up to date version of seas0pass I have successfully jailbroken my atv2. However, once I run the tethered boot and connect the device to my tv the atv will not connect to the network properly.
-I am given the start up options. I select the language and my wifi network.
-The next step, activating, then fails.
-I can press the back button which tells me setting date and time. This clocks continuously.
-If I press back again I am taken to the home screen and the only icons available are computers and settings. The settings do reflect the FC logo.
I know the network in my home is working. My ipad is still connected and running. I also know the atv is connected to the network because I successfully loaded xbmc and have watched programs on it.
Any suggestions would be greatly appreciated.
