Purchased the software and followed the instructions to create the USB flash drive however on booting with it Im getting the following display.
init started: BusyBox v1.18.4 (2011-05-14 22:20:46 MDT)
/etc/init.d/rcS: line 81: [fsck: not found
atv-boot=patchstick failed – starting telnetd
udhcpc (v1.18.4) started
Sending discover…
Sending discover…
Sending discover…
No lease, failing
eth0 Link encap:Ethernet HWaddr 64:B9:E8:FF:1A:FA
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:20 Base address:0xc000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
Apologies as I couldn’t attach a screen shot.
Please help as I have no idea where to go from here and it is turning out to be a massive headache.
Many thanks in advance.
