aTV won't boot from USB Stick
I’ve tried to create the patchstick, created it without any errors, but my aTV won’t boot from it. Tried another stick(Kingston Datatraveler 2.0 1gb) same issue.
The strangest thing now is that we get the following messages when I try to recreate the stick after formatting the entire stick.
Reset the atv, reinstall the 2.0.2 update…
[code]macbook-van-karin-de-rooij:aTVflash3-0 karinderooij$ sudo ./createPatchstick /dev/disk3
— aTV Flash Version 3.0—
by Apple Core, LLC
Are you sure you want to partition disk /dev/disk3? [yes|no]yes
Partitioning /dev/disk3:
Started partitioning on disk disk3
Creating partition map
Formatting disk3s1 as Mac OS Extended (Journaled) with name Patchstick-root
[ + 0%…10%…20%…30%…40%…50%…60%…70%…80%…90%…100% ]
Finished partitioning on disk disk3
/dev/disk3
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *499.9 Mi disk3
1: Apple_HFS Patchstick-root 499.8 Mi disk3s1
Patitions done.
Copying Files…
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/AGRegex.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/AGRegex.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/AGRegex.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/AGRegex.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/AGRegex.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/AGRegex.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/atvfiles/ATVFiles.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptCore.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptCore.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptCore.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptCore.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptCore.framework/PrivateHeaders with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptCore.framework/PrivateHeaders
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptCore.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptCore.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptGlue.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptGlue.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptGlue.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptGlue.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/JavaScriptGlue.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/JavaScriptGlue.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/OpenAL.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/OpenAL.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/OpenAL.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/OpenAL.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/OpenAL.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/OpenAL.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebCore.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebCore.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebCore.framework/PrivateHeaders with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebCore.framework/PrivateHeaders
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebCore.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebCore.framework/Resources
cp: symlink: Versions/Current/Headers: File exists
cp: symlink: Versions/Current/PrivateHeaders: File exists
cp: symlink: Versions/Current/Resources: File exists
cp: symlink: A: File exists
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebKit.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebKit.framework/Versions/Current
cp: symlink: Versions/Current/Frameworks: File exists
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebKit.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebKit.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebKit.framework/PrivateHeaders with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebKit.framework/PrivateHeaders
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/couchsurfer/Frameworks/WebKit.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/couchsurfer/Frameworks/WebKit.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/LeopardOnly.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/LeopardOnly.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/LeopardOnly.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/LeopardOnly.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Headers with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Headers
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireCompatClasses.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireLeopardCompatClasses.framework/Resources
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Versions/Current with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Versions/Current
cp: cannot overwrite directory /Volumes/Patchstick-root/stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Resources with non-directory /Users/karinderooij/Desktop/aTVflash3-0/atvflash//stuff/sapphire/Sapphire.frappliance/Contents/Frameworks/SapphireTakeTwoCompatClasses.framework/Resources
Changing Patchstick-root to Apple TV Mode…
Unmount of all volumes on disk3 was successful
/dev/disk3s1 removed
/dev/disk3s1 added
Your disk /dev/disk3 is now unmounted and ready to patch your AppleTV.
Enjoy… :slight_smile:
[/code]
Already downloaded the installer twice.
Downloaded Step 1 (OSBOOT image) twice.
Please assist…
Replied in other thread.
