Atv suddenly dead?
I've been running ATV black with FireCore/ Infuse for some months now untethered. Yesterday I found by atv stuck at the spinner (my wife was using it, no idea if if anything actually happened).
Now the atv is stuck at this stage even after a day. Rebooting after powering off gives blinking led during boot and ends up in the spinner again.
Any idea what might have happened and- more importantly- how to fix it? Restore in iTunes? Be careful to get a specific version to not loose jailbreaking?
Cheers,Andi
Tried but still stuck. After 15secs the lead blinks couple of times, tv goes blank. When tv comes back I'm stuck at the spinner again.
Any ideas?
THANKS!
[quote="andig"]
Cheers,Andi
[/quote]
[quote=andig]
Any ideas?
THANKS!
Could be internal memory full. This happens if you airplay a lot. Easy way to clear it up , rejailbreak with seasonpass. Your atv is not dead.
Thanks guys. Re-jailbreaking did the trick. Not sure I like the behavior though...
Always check these folders and empty it via ssh as root:
/private/var/mobile/Library/Caches/AppleTV/Video/LocalAndRental
/private/var/mobile/Library/Caches/AppleTV/Video/Other
Here is the space where cache sits.
