On any web page I am on, the cursor will patially move one time and then freezes. Attempts to move it again do not work. Attempts to remove the cursor fail. In fact, the ATV is locked up and I must unplug and reboot. Why? Fix? Thanks
Are you attempting to access web pages with Flash video? If so, you will need to enable Flash first.
Do you mean if you attempt to run the flash video on the page or just opening a page that has flash video and then trying to move the cursor anywhere on screeen, not just to the flash part?
Unfortunately yes. If you attempt to move the cursor around such a page without having Flash enabled, the result will be as you described.
Thanks for clearing that up. I do appreciate your time.
