Hello,
i was very happy when infuse started supporting mkv DV files… now BR remux files that were both HDR and DV played back as DV…
BUT…
Lord of the rings Remux trilogy is played only has HDR and not dv.
Can you please check
[code]
General
Filename…: The Lord of the Rings The Fellowship of the Ring 2001 Extended Edition 2160p UHD Blu-ray Remux HEVC DV TrueHD 7.1-HDT.mkv
FileSize…: 115 GiB
Duration…: 3 h 48 min
Video
Codec…: HEVC Main 10@L5.1@High
Resolution…: 3840x2160
Aspect ratio…: 16:9
Bit rate…: 67.9 Mb/s
Frame rate…: 23.976 fps
Color primaries: BT.2020 - Dolby Vision / HDR10
Audio
Language…: English
Channels…: 8 CH
Format…: Dolby TrueHD with Dolby Atmos
Bit rate…: 2 994 kb/s
(Surround 7.1)
Audio (#2)
Language…: English
Channels…: 6 CH
Format…: Dolby Digital
Bit rate…: 448 kb/s
(Surround 5.1) [/code]
This is a Blu-ray rip into a single layer MKV (profile 7) where the DV information has been retained. Infuse has never supported playback of the Dolby Vision layer of these files, standard HDR is the best you are going to get.
This is an Apple limitation and it is unlikely it will ever be supported natively.
