aTV Flash xbmc edtition won't install
Installation has been stuck on the init started: BusyBox v1.18.4 screen with a flashing prompt. Been stuck there for 30 mins which I’m guessing isn’t correct.
Tried this twice and the same thing happens. Any help to get up and running appreciated.
Update: Just a black blank screen now.
Update 2: Three USB sticks later and I’m up and running.
Glad to hear you’re up and running.
The flash drive type can definitely make a difference.
