It’s a SHAME!
Nearly one week went by since the bucks disappeared and no - absolutely NO - solution for the problem. Neither any response to frequent support requests. What kind of business ist this?
:shock:
It’s a SHAME!
:shock:
Hello Admin,
I have just purchased your aTVflash Software and it just will not create a USB Flash drive.
I have the same problem as many in this thread. I am doing everything according to the instructions but when I start the aTV Flash installer it stays at
0% copying files.
I also downloaded the Java update but still no help.
Please tell me which information you need that I can get this thing to work!
Maybe also someone else has a good idea that helps.
Best regards
TWWB
Please contact our support department at Firecore - Video Player for iPhone, iPad, Apple TV, and Mac
Okay - I did contact you via Firecore - Video Player for iPhone, iPad, Apple TV, Mac, and Vision because having the same problem (stated several times here) … And NOTHING happens for more than 5 days. ![]()
Hello aTV Flash support,
I hve contacted you now twice via email and still did not get any answer from you.
You have deducted the USD 50,- from my credit card account and since than I have not received
anything from you, not even an answer.
Is this how you treat your customers???
Do you have any timeframe when you will have solved the problem?
Do you have any alternative in the meanwhile?
For example: sending me a working USB-Stick !!
Is the problem (stated already several times) solved with version 3.2.3 ?
I AM REQUESTING AN ANSWER !
Best regards
twwb
Order Number: 5540
Seems you need not to expect any answer. I have submitted 4 requests to the support. No usable answer by today. Just one which was standard and could be read in the forum too (And I read it prior to submitting a support request).
This problem is only affecting a small percentage of users, and is related to a software conflict on the affected systems.
We are working to determine the exact conflict so a fix can be implemented. Please bear with us during this time.
If you would rather not wait, send us an email and we can issue a refund.
i have the same problem… copying 0%. I have download the update of java and follows equal. my usb is microvault of Sony model usm-d plus with 1gb and other with 2 gb. i need help you
Please send us an email through our site at: Firecore - Video Player for iPhone, iPad, Apple TV, Mac, and Vision
Wasn’t having a problem with the previous version of the software, but having the same problem now with the latest release. 3.3
Sent an email
I follow without being able to use yours sofware. I need a solution or
to give back my money. the problem is not stick since I have proven 2
marks recommended by you :evil: :evil: :evil: :evil: :evil: :evil:
This problem has been correlated to a conflict with another software application that is currently running on some systems. We’re trying to narrow it down, but have not found the culprit as of yet.
Please send an email through our site at: Firecore - Video Player for iPhone, iPad, Apple TV, Mac, and Vision
Found the problem: /Volumes/Patchstick-root already existed as a local directory owned by root. Just remove (or move) it and this will allow the aTV Flash Installer to create the mount under the appropriate name and copy the files. With the pre-existing directory in the way, aTV Flash will create “/Volumes/Patchstick-root 1” and it will sit-n-spin all day trying to write to the one owned by root.
Interesting. What was the first version of aTV Flash you installed?
Interesting. What was the first version of aTV Flash you installed?[/quote]
It was from September 3, 2008, so whatever the current version was at the time. It might not have had anything to do with ATV Flash. I’ve build several Patchsticks on my own and they used the same name for the volume. It could have been created as a result of that. I found it while troubleshooting a problem building a patchstick manually. I wasn’t seeing any files in the Patchstick-root partition on the USB drive, so I started tracing the createpatchstick.sh script with (sh -x) and that eventually led to finding the local /Volumes/patchstick-root. With it removed, both ATV Flash and the manual script ran fine and I was able to create working patchsticks. I’m back to using yours again since I don’t want to have to maintain them.
I’m happy to report that the new NitoTV 0.5.6 with DVDPlayback.framework works like a champ. I can finally play DVDs (with menus!) on ATVT2! Had to fiddle with the TV resolution and NitoTV safe restore settings (it didn’t like 1080p right way, but got it working), and now I can play .iso DVD rips on Apple TV. It even works over wireless (NAS is in another room where the noise won’t interfere with the movie). I get about 17-20Mbps and that’s just enough. Picture and audio are smooth and clear. Response to remote control is instantaneous. I’m going to have to change my forum handle now.
Ok, but that we have to do? Can you it explain step along step?
Be sure not to have the USB stick installed. Then when you are in Finder, click the Go menu option and then Go to Folder… . From there type /Volumes in the dialogue box and it will take you to the Volumes folder. If you see a Patchstick volume there, either delete it or move it. Since the problem didn’t happen to me, this is my best guess on how to do what “nothappy” wrote about.
I was having the same problem. Your suggestion worked for me nothappy and madcran. Thanks a lot. ![]()
To fix it, open terminal
L12948bjornb:~ bjornb$ ls -l /Volumes/
total 56
lrwxr-xr-x 1 root admin 1 Oct 12 01:00 Macintosh HD -> /
drwxrwxr-t 26 bjornb staff 918 Oct 2 11:37 OSBoot
drwxrwxr-x 12 root staff 476 Oct 12 09:29 Patchstick-root
drwxr-xr-x 1 bjornb staff 24576 Oct 11 17:18 Untitled
drwxr-xr-x 12 bjornb staff 476 Sep 22 17:33 aTV Flash
L12948bjornb:~ bjornb$ sudo rm -rf /Volumes/Patchstick-root
Password:
Worked for me.
