I bought ATV Flash Beta and tried to install it. The installation seemed to work ok until I ended up getting this message "Sorry, the installer could not connect to your AppleTV. Help!" Just before I received that message the installer saw my Apple TV with its IP number.
I am just wondering if jailbreaking with Season Pass worked or not. How do I know it did? I know my Apple TV was visible in an iTunes window after the installation.
What should I do now to successfully install ATV Flash. I am running Mac OS X 10.6.6
I am having the same issue. Another issue that I am having is that I do not see my computer that I have iTunes installed even thought I have home sharing turned on and and Airplay tuend on Apple TV and Homesharing turned on my PC. USing windows 7 64 bit..
Im having the same issue. I have home sharing turned on and and Airplay turned on Apple TV and Homesharing turned on my mac. I completely followed http://support.firecore.com/entries/346673-installing-atv-flash-black - I dont get it???
To ensure the jailbreak was successful you can try connecting via SFTP by following the guide here. If you're not able to connect you may need to re-jailbreak.
I am having the same problem. Jailbreak seemed to work fine and when I tried to install ATV Flash Black I get "Installation Failed - Sorry, the installer could not connect to your AppleTV" Any suggestions?
i'm having the same problem. Up until 'Select Apple TV' in install 'ATV Flash Black' all goes well. The install program sees the correct IP adress of my Apple TV, but after that i get the message installation failed. What could the problem be? I'm connecting through wi fi on my time capsule. Please help!
I have the exact same problem - that is, when it comes to selecting the Apple TV from the menu (during which the installer correctly display the IP address of my ATV 2g), and when I hit next, it says that it is transferring files. But then I get the error saying that "Installation failed" and "Sorry, the installer could not connect to your Apple TV."
I have even tried connecting the ATV directly to my MBP through an Ethernet cable, but I get the same error. Definitely a bug with the installer. A shame because I just bought a lifetime subscription and it's my first use, and it's NOT working!!
