ATV Flash for 3rd Generation
Hello,
ATV Flash not for 3 rd Generation? (the generation just before 4K I mean)
Mine is black, thin and with silver remote you caled it 2nd gen and Apple 3 rd ..
Bit confused ..
:wink:
Some explains?
Thanks in advance,
Frederic
ATV Flash is not for Gen 3 only Gen 2 or earlier.
Gen 2 and 3 look very similar and use the same remote so you have to go by the Apple part numbers in the page referenced above.
Hi, itโ€™s a 3rd Generation.
Is the patch also works on this or is there another way to install INFUSE on it?
Regards,
Frederic
