kelley
November 12, 2009, 5:52pm
1
Hello,
I just downloaded the newest atvflash and when I launch it, it gives me an error and quits. It reads that I am either not connected to the internet or its an old version. I am connected wirelessly on my MB Air. Any ideas on how to fix this? If I download another copy do I get billed again?
max
November 12, 2009, 6:07pm
2
It sounds like you have an outdated copy. Downloading a fresh copy should get you going.
To locate your download link:
Click the My Account link near the top of any page of our site. (http://www.atvflash.com/ )
Log into your account.
Locate your order in the ‘download links’ section and click ‘view’
The download link will be near the bottom of the page
julpi
November 15, 2009, 6:54pm
3
I have the very same issue and I’m sure I have the latter version (4.01).
I think there is some issu with Atv Flash servers, maybe related from the forums recent DB connection issue?
Anyway, at the moment I’m completely stuck, unable to create a new patchstick due to thi s error anytime I launch aTV Flash.
Parel
November 16, 2009, 5:54pm
4
I have the same problem and I 100% sure that I am using the 4.0.1 version, any help?
YinZhe
November 17, 2009, 10:03am
5
Same issue but only from few days…
But I have some Internet access problems those days, it should be linked…
Otherwise, the packaged I use is good (freshly downloaded, installed and used one time successfully) and it is the lastest release : 4.0.1
