Hi!
This was originally talked about here:
Hi! Great work with aTV Flash Black! Managed eventually to stream my Flacs to my AppleTV2>DAC! Very gratefull!
I have many 24/96 Flacs though that cannot be played with aTV Flash! Every time i try so it seems that aTV Flash is starting to play the tune but immediately skips to the second, third, forth and so on track! I can play them with iTunes through Home sharing but i have to decode them first to .wav format with Flac Frontend!
Am i doing something wrong or aTV Flash cannot support HD Fla…
I’m trying to play FLAC files in Infuse on the aTV Flash (Black) from a network drive. 16bit/44.1k files play okay, but it will skip tracks. Then 24Bit/96k files play a few seconds and stop for a few seconds. Is there anything I can do to make them playback?
Thanks!
I got it figured out, it was an issue with my network. Everything is working great now!
system
Closed
May 26, 2020, 9:26pm
3
