Hi all, I read tons of forum messages and tweaked a lot but with no prevail.
1.5TB WD drive (yes, I disabled the VCD), formatted to Fat, empty, brand new.
When switching to external as primary my ATV attempts to synch files onto it but crashed after 2 seconds and reboots. I changed from internal to external many times, always the same.
Also: when in external mode, my ATV still finds all music that are on ATV and plays it there too. Just video is not available (but comes back when switched back to internal).
This is weird and time consuming, thanks for any help.
OK, I ran it AS ADMIN and it startd but now it tells me my HD ist write protected, starts the Windows format facility in between multiple times and throws errors at me. I can format NTFS both on the HP tool and Windows but not Fat32
Apparently it stopped complaining, it shows that it is formatted as Fat32, connected to ATV, set as external, transfer screen on for 1 minutes, ATV reboots, HD remains empty… I am close to give up and ask my money back. I wasted many nights over this now
While (after trying several times) the external drive remains empty, why does ATV not recognize 90% of the movies in MyMovies but does play 10%, obviously still from the internal drive while the external is on…? This is all very strange.
After more trying: ATV attempts to transfer onto the new external but reboots after a minute, it is fat32 formatted with the recommended tool but it does not work
It’s more likely to be an external drive issue. What name did you give the drive? Were you prompted to select the drive from a list when switching to external iTunes storage?
yes, that’s what I wrote above… the drive’s name shows in nito’s files option but i don’t et any selection for any drive when switching the usb drive to external
i bought the drive ONLY to use it with atv, now the 7 days have passed when i could have brought it back to the store, including atvflash thats a 200 bucks investment that does not work at all, really frustrating
Now, which allocation unit size??? The tool only formats with 32768 and not as shown in th screen shot with 4096. I get an error message "This drive has more than 2^28 clusters, try to specify a larger cluster size or use the default "
