ATV constantly rebooting
Hi, I have just updated to ATV 2.4 and ATV Flash 3.6.1 and now each time I go into Nito TV or Sapphire or almost everything I get a message saying something like “Apple TV encounter an error and need to reboot. Press play/pause to reboot”. I try to use couch surfer and the same happens. ATV files updated and is working fine. XBMC also works fine. Someone has the same issue? Is it a known bug or is it only my problem? Thanks very much in advanced.
It only happens when I use the remote app to control the ATV. With the white little remote everything works ok. Any ideas?
also with the loop controller for me…
Many of the plugins for the Apple TV does not support the new gesture based iPhone Remote. The developers are working on it.
