Hi everyone,
I’ve searched pretty deeply and I’ve found similar reports, but nothing describing exactly what I’m experiencing. And none of these other posts have ended with a resolution.
Specs:
ATV4K Gen 3 Ethernet
LG G4
Infuse 8.4.7
tvOS 26.5
Cache - Legacy
Wired connection
This happens with HDR and DoVi files (profile 5 and 8). It always seems to happen when there is a sudden change in brightness with whatever I’m watching, like an explosion, or a lightning strike that quickly brightens the screen or creates a big flash. The video will freeze on that frame while the audio continues. And then the video will pick back up in a few seconds. Sometimes if it’s a DoVi file it’ll kick itself down to HDR. But again, this happens both with HDR only and DoVi files.
Edit to add more to this: Tested the same file using Infuse both on my iPhone and macOS and the problem persists on both devices. They don’t freeze like on the ATV, but they will artifact and hitch and then continue playing. So it seems this is an Infuse thing and not anything with my setup or my HDMI cable.
Let me know!
