I have a couple “Dolby Core Universe” demos that I downloaded. One was a m2ts and another was an mkv from https://thedigitaltheater.com/dolby-trailers/. I cannot seem to get atmos playback through Infuse. Can others try it out? And yes I did select the DD+ audio stream once I started playback.
Audio #2
Menu ID : 1 (0x1)
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Format profile : Blu-ray Disc
Muxing mode : Stream extension
Codec ID : 132
Duration : 3 min 7 s
Bit rate mode : Constant
Bit rate : 1 664 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 37.3 MiB (4%)
Service kind : Complete Main
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Or if someone has a link to one that does work that would be great. Thanks
