I’ve been trying to figure out why this is happening. I manually change artwork in the media folder (outside of Jellyfin). Jellyfin sees the new artwork and updates the artwork in Jellyfin, however the artwork in Infuse does not change. I have library mode on. The only way I can get it to update is to toggle local artwork off and then back on again. I figured I’ll change to local artwork off, however the same happens - this time toggling local artwork on and off triggers the artwork refresh in Infuse. Seems its the only way I get it to work…Force closing and reopening the app does nothing, and refreshing items individually does not refresh the artwork. Does anyone have any idea what is going on? After much playing around with it, I can only assume bug at this point. If the devs could take a look at this it’d be very much appreciated.
Note: I have library mode on.
Edit: Figured toggling literally any of the options in 'Metadata & Artwork. either off>on or on>off will trigger the image refresh/change to match what is in Jellyfin. Please let this be fixed!
