Artwork not available on themoviedb.org
Hello,
Time to time Infuse can’t find the artwork of a movie on themoviedb.org. How can I define some artwork for this particular movie?
By the way I’m also using Synology’s DS Video with my Nas, I don’t know where they are going to download the movies’artworks but the program always find them. And the one Infuse is not able to find DS Video does.
Thanks in advance for any advice.
Best regards
Pascal
Can you provide an example filename for something that isn’t getting a match?
You also have the ability to add your own artwork, if needed. A bit more info on the options for this can be found here.
