I’m new here, so I hope to get answer to my problem, which I think concerns a lot of people !
So before the last update, everything was nice and super ! Nothing to say but bravo !
But with the last update, a lot of covert art/tile of my movies disappeared. All the metadata is good, it finds the movies or so but the tile/covert art is not like before.
It shows a dark tile with the name of the website I downloaded it from. It never shows that before, several movies did change their tile by themselves whereas it had the good ones before.
i have embedded metadata disabled. the movies are in a directory together with an jpg. sadly the poster shows the jpg. the other metadata (title, background image, …) is loaded correctly. i can not get infuse to ignore the jpg.
As I understand it ‘Embedded Metadata’ refers to information/images actually embedded within the video file itself; so turning it off will not prevent the loading of a jpg in a separate file.
I assume that you are talking of a jpg which has the same name as the movie, so I guess the question is why you are not wanting it to be displayed.
Other than deleting/renaming the jpg I don’t know of an option to prevent it loading the jpg if it’s name meets the naming convention that Infuse uses.
