AppleTV not responding to Remote
After a failed attempt to load a VIDEO_TS file into my movies directory my apple tv remote is not working. The indicator light blinks orange with each button press, but I get no menu activity. Has anyone else come across anything like this? Any help would be appreciated.
Cheers,
Mr. D
Edit:
Problem solved ! Somewhere along the failed upload it reset the remote pairing. To fix this hold down menu and the rewind button for 6 seconds. Then you are able repair. Good to go.
