AppleTV frozen on First Screen
I have asked about this before
My problem is that all I see is the opening menu for the AppleTV and can get no further.
The remotes will not activate any of the menu items so I get no further and am unable
to access any of the menu items beyond the initial screen. Hence I cannot restore, upgrade or do any maintenance on the set.
This occurred after I upgraded Boxee.
The AppleTv is on 2.2 and I have upgraded the ATV to the latest version
The set restarts when I unplug & replug it, but every time it stops at the screen headed Movies with the tv at the top
I have tried 4 different remotes and still nothing changes
It will not reset with menu and - buttons
Surely someone out there knows the secret to fix this problem!
regards
TND
Can you log into the AppleTV with Fugu and see if this file exists. Go into Library > LaunchAgents and see if it is there. If so then try what is suggest here:
http://forum.boxee.tv/showthread.php?t=722&highlight=remote&page=3
and go down to the bottom post #30 and see if that works. It is a conflict with Boxee and the AppleTV Remote software I think.
EDIT: Just realized I never put in the name of the file that needs to be removed or deleted: tv.boxee.helper.plist
Thanks madcran
I located the “tv.boxee.helper.plist” file in the library folder.
deleted it manually and then restarted the tv by removing the power cord.
Everything now works as it should
thank you so much for your help
regards
TND
