I have a appleTV Software Version 3.0.2 buyed in Juni 2010 and installed aTV Flash, everything work very good but i can't enable AFP
what i have to do
what i have to do
Unfortunately AFP is not supported on the newer AppleTVs (those purchased after October 2007). SMB can be used in it's place. Setup guides are available here.
[quote="max"]
[/quote]
That's not quite true....
It's possible to get AFP working with 3.0.2 (I have it working myself)
You will need a copy of the original 1.0 firmware. Don't ask me where to get it. The files are not legally distributable....
If you are able to get the file, copy it to your /users/frontrow/Documents folder and run the Smart Installer in order to enable AFP support....
Alternatively, if you have one of the original AppleTVs that had 1.0 pre-installed AFP can be enabled by following the guide here.
