Today i received my AppleTV preinstalled SW V. 2.2.
If I update to 2.3 nothing is really working anymore if after I applied the ATVFlash patch newest version.
XMBC is not starting at all.
THere is no chance to mount any network drive via SMB.
So for what did I pay?
I thought you guys are the first ones to support Version 2.3 of the Apple TV. IS there something I missed?
After reinstalling the latest aTV Flash, did you see the install scripts on the screen, and does the ATV menu show the latest aTV Flash version?
Mine is working fine under the latest Apple TV OS and aTV Flash version, but it did take some work.
Did you drag an OSX disk image into the ATV using an FTP/SSH utility like Fugu or Cyberduck and did everything ever work right under older software versions? Did you go thru the complete installation instructions?
Also, did you “update” the aTV apps after the installation using both the xmbc and boxee updater as well as smart install under Nito/DVD?
Remember, the aTV Flashstick lays the “groundwork” for the basic underlying hacks. You still need to install the OSX Image and update the other components for it to work.
“Are you a hacker or a slacker?”
Jambaleia, I emailed you directly, via this Forum, with some details about making an SMB connection. Did you see that and did you try them? Many of us have had to figure out some of the details on our own but we are on this forum to help others, as well as get answers to question. Let me know if you got the email (check your user Control Panel) and if there was anything useful in the specifics of creating an SMB (or AFP) share.
I was using the wrong parameters for awhile and thought the ATVFlash was working. It was and as with any software, since they are using other supplied programs, like NitoTV, we have to live with it if we want the benefits.
I think they can be faulted for not having step by step instructions.
If I connect to my ATV via Cyberduck go to movies folder I see a folder called video. THis folder is my SMB share on my link station. If I now start do digg deeper i cann access the link station via the atv ftp connection!!! Now I am really confused…
That is really something I am not happy about. If you check other posting the only thing ATVFlash is linking to is the how to how to enable SMB mount. But this is not working at all.
So I really would like to get someone from ATVFlash here to reply to the problems.
I did, this thread was getting off topic and I didn’t feel that the added comments by other users had any technical additions to the thread. This thread started to become a place for other users to complain and that is considered a Lounge area. I had three choices here:
Delete the posts that didn’t add to the thread and piss off the people who already are ■■■■■■ off about the product.
Move the thread so it could continue as a “I hate aTV Flash” thread to let users complain.
Leave it where it is and take the chance that more ■■■■■■ off users would continue to post in a place where it doesn’t belong.
After thinking it over, I’ll change my stance on this thread, I’m going to change the name of the thread, move it to where it should be and delete the posts that don’t belong here. In the process I guess I’ll just piss more people off though. Unfortunately as the moderator here I have to keep some sort of handle on the threads so they don’t get off topic. As for your problems with aTV Flash I would help you if I could, but I can’t help everyone with every problem as I don’t have experience with some of the things that other want to do with their Apple TV. I help where I can, but my main job function is forum moderation. It was not my intention to “hide” the thread and I apologize for that.
But to be honest. We are not discussing “a problem” here. The specs are telling that a connection to an SMB share is possible and if you go through a lot of posts here in the forum this is not working for a lot of people. So I wouldn´t say it is just a problem with ATVFlash
If you are not able to provide support who can? Because ATVFlash also states that with the 50 Dollar you get access to a support forum!?!? Where is this support forum where I can post something and someone is checking it?
There are two ways to get support, you can post a question here and either myself or aTV Flash will answer it or you can contact aTV Flash directly but using the contact page:
The main reason I said I couldn’t help you is because I don’t have a LinkStation, but let me see about setting up a SMB share and connecting via XBMC and I’ll let you know what happens.
I don´t know what I did but today I found under “nito TV → files → my SMB share”!!
The problem I am focussing now is that the movies are played but not really good. That means that I have lags. Is that normal? Does that has something to do with the avi file? Is that a streaming problem?
My setup is a GIGA network cable (CAT5) through the whole appartement. So it should be a speed issue. The server which is my SMB share a giga connection as well.
