Hi
With the last 2 versions whenever I try to play a file from the “Files” menu i get this message:
Apple TV’s volume was very low. Turn down your TV or receiver volume before continuing. (Image of this screen is attached)
I need to hit “OK” , then it takes me to a frozen screen and when I press menu it takes me back to that error screen. After 4-5 times repeating this process everything is fine.
I had this problem as well when trying to play H.264 files. When I changed the video selection in the Nito settings to quicktime instead of perian it seems to have fixed the problem and I don’t get the message anymore.
I had this problem running XViD files - Go to the settings and disable the volume control on the AppleTV. Assuming you’re controlling your volume with an amplifier, just disable the AppleTV’s volume control.
