Does anyone have this problem? Ever since I installed Apple TV Flash, my remote is very slow and hesitates when I try to scroll or try to type on the input screen. I set up a non apple remote and have the same slow, unresponsive issues.
I have the same problem! The answer support atv,
What type of files are you viewing when the issue appears? Is the Apple
TV setup to sync with your computer? During a sync operation the Apple TV
menu will run a bit slower.
Thank you for your business and time.
so if someone more competent to an idea
thk
May 2013… and I have the same un-resolved problem.
FireCore: please advice.
