apple tv failed power supply
i have had atv flash black on my tav for ages now, but ever since a few updates ago it hasn’t been working properly and i can’t seem to fix the problem!
problem being, every time i disconnect the main power cable, the white light on the front has a hissy fit and tells me i need to connect it via usb again! it never used to do this! so i can’t get atv flash black to load again on it and season on pass will only do a tethered boot which works, until i disconnect the power so i can plug it back into my tv in another room and it starts all that crap again! it also won’t restore in iTunes!
what do i do???
It sounds as if you do not have the latest untethered jailbreak installed?    It might be worth re-downloading SeasonPass to ensure that you have the latest version and then repeating the jailbreak process.
