I cannot connect to my MAC shared library via Apple TV.
although it sees the folders but no files
What protocol are you using to connect? SMB, FTP, DLNA, etc.?
SMB on my MAC MINI M!
There’s a good users guide here that has info on set up and trouble shooting.
I read that. I could connect with my previous Apple TV. got the new Apple TV and connect see videos. please help. I am a pro subscriber
I read that. I could connect with my previous Apple TV. got the new Apple TV and unable to see videos on Apple TV - it is empty. please help. I am a pro subscriber
There are a few things to check.
If you’ve recently installed an update for macOS, you may need to disable and then re-enable File Sharing to get it working again. You can also try one of the tips found here. https://www.stratospherix.com/articles/fb141019.php
Note: iCloud username/password cannot be used. If you’re using an iCloud ID to log in to your Mac, you will need to set up a new ‘Sharing Only’ user as described here: Change Users & Groups settings on Mac - Apple Support
I tried all this steps. nothing allows me to connect from my Apple TV to my Mac via infuse.
infuse is working fine on my Mac.
what else please?
I still cannot connect. can you advise please
I need help. so frustrated. my Apple TV infuse does not connect to smb Mac mini
please help.
I also get message on infuse appletv indexing failed
