Apple Tv + Airpods = Audio out of sync
Hi!
I’ve been encountering an audio sync problem while using the Infuse app on my 1st Gen Apple TV 4K with AirPods Pro (A2698). Specifically, when I have my AirPods Pro connected, the audio seems to be out of sync. However, when I disconnect them, the audio returns to normal.
To mitigate this issue, I’ve resorted to manually calibrating the audio with a delay of 150ms, which provides a decent sync.
I’m curious if anyone else has experienced similar issues and if so, how have you addressed them? Have you tried different audio correction settings aside from 150ms?
Looking forward to hearing your experiences and any potential solutions you’ve found. Thanks in advance!
2 posts were merged into an existing topic: Audio Sync with Airpods Pro on Apple TV 4K
