Enhance dialogue and Reduce Loud Sounds are enabled on Apple TV 4k but when playing anything on Infuse Pro both don’t work. I wonder why on Airplay it works and not on actual Apple TV 4K Infuse Pro app
These features are very important these days and I hope you can update your apple tv 4k app and give us the options.
Currently this requires that you are using HomePods.
I am using homepod 2 but the option on the apple tv 4k infuse pro app isn’t showing
I think this issue is over a year now and you still haven’t provided any resolution yet. I’ve been seeing a lot of requests and issue like this but still no luck.
The way I read it is these settings are in the Apple TV 4K settings not the Infuse settings. I don’t use this so I’m just going by the posts.
Yes but other apps automatically follow the apple tv 4k settings like for example netflix but Infuse Pro app dont
Netflix uses Apples video player. Infuse doesn’t.
That’s weird but when I play trailers on Infuse Pro it activates the Enhanced Dialogue. This is a feature that should work on the videos as well.
I’ve been using infuse pro for a few years and have just started using HomePods with my Apple TV.
Unfortunately I am going to have to give up on infuse as the sound is awful, no matter what I do to the settings I can only just hear the dialogue, my partner who has a hearing aid misses nearly all the dialogue.
Streaming apps like prime, player and Netflix all sound great following the Apple TV settings, infuse is just a booming, mumbling mess!
I’ve tried several other apps, HamHub, SenPlayer, HD Player and a few others, and although nowhere near as slick as infuse, we can at lease hear what we are watching.
@james Is this being looked into?
Also why is it still not possible to integrate shortcuts into the Infuse Player UI that allow quick access to the two functions (Enhanced Dialogue + Reduced Loud Sounds)?
Is it technically absolutely impossible, or are there other obstacles?
I can confirm that “Enhanced Dialogue” and “Reduced Loud Sounds” do not work in Infuse when using two HomePods (2nd Gen) as audio output.
I have tested this with various movies and sound test files. When playing the same movie in the Apple TV+ app, these features work as expected, but they do not function in Infuse.
tvOS 18.3, audioOS 18.3, Apple TV 4K, 3. Gen
It would be great if you could fix this quickly. It has worked in the past.
@james Is there anything I can do or any additional information I can provide to have these issues reviewed and fixed?
We’re looking into a few other reports of an issue related to Atmos with HomePods so it’s possible this is related to what you are seeing.
Today’s 8.1.3 update has a number of improvements for Dolby Atmos and HomePods audio.
In our testing we are seeing identical behavior when playing files in Infuse and Apple’s own apps when Enhanced Dialogue and Reduce Loud Sounds are enabled/disabled.
