Apple TV 2(need some help)
Hi
i need some help. i have apple tv 2 on 5.1 and after when i installed this i have only icon of settings and and media library from my mac
Are you saying that you think you have successfy jailbroken the ATV2 with the latest SeasonPass?   If so you will not get any new icons until you have installed the FireCore software on the jailbroken system (which adds the maintenance menu icon).   The Maintenance menu can then be used to install other Firecore componenets.
Thx)
