Downloaded and installed on atv gen 1. everything works just as stated on your instructions, however the menu never changes and if I try to go to the maintenance menu it appears flashes the apple logo and goes back to main menu. Please help
I am having same problem, does anyone know what is the problem and how to fix?
In my experience in this sort of circumstance you need to do a factory restore:
- Press and hold both Menu and down (-) on the Apple Remote for 6 seconds or until the status light blinks amber.
- The Apple TV should Reset itself and show you a screen where you can select one of the following: Restart, Run Diagnostics or Factory Restore.
Follow this by updating the apple software, then re-appying the latest version of ATV flash and finally re-syncing your whole library
Can take ages, depending on your network speed.
Good luck
[quote=the3rdParty]
Good luck
This does not work for me.. When I install Firecore it only takes a minut or so.. Is this correct?
My atv works fine, but has not installed Firecore, WHY.. Please help..
This happened to me...is there a fix. Is anyone supporting this anymore? There's lots of old posts.
