APFS Vs ExFat : What's best for Infuse?
Hello,
My movies and series are on a big external HD connected to my Mac.
I access them with my Apple TV 4K.
What is the best or fastest format for the HD, APFS or ExFat for INFUSE ?
I already know the differences between the two for the Mac.
Thank you :slight_smile:
Pretty hard question to answer, but specifically for Infuse from tests that I’ve done APFS is the winner. The real question would normal be HFS+ vs APFS, and in those tests APFS reads faster (better for Infuse) while HFS+ writes faster. exFAT is slower than both, but it allows you the option of moving the drive between Mac and Windows.
Thank you, it’s all I needed to know :slight_smile:
