This is me being fussy…but when I look at a movie via the app, I use “Play”, don’t ever use “Rate”, not going to be using playlists…but now the frequently used “Delete” is an extra step down, hidden under “More”…which requires more work by me with the remote.
Is there any way to hide some of these options or resort them?
Phil
+1 here!
I also never use „Rate“ and hardly ever „Refresh“. Those two options really should be replaced with the new PLAYLISTS and the DELETE option.
Agreed. RATE and REFRESH should be moved to the More sub-menu.
james
October 31, 2019, 5:08pm
6
We’re adjusting the button order for the upcoming 6.2.1 release.
The new order will be:
Play
Mark as Watched/Unwatched
Playlists
Delete
Rate
Edit
Hey James ?
Can you reduce the Buttons on the Screen to 3? That means 3 Buttons + „More“…
james
October 31, 2019, 5:21pm
8
We don’t have any plans to change this right now.
Would have preferred “Playlists” and “Rate” to be the hidden ‘More’ buttons, but hey, happy that delete is gong to be less complicated…thanks!
james
November 1, 2019, 5:35pm
10
6.2.1 has been submitted to Apple, and should be available within the next few days!
system
Closed
May 15, 2020, 8:36pm
11
