I just transferred over a few fairly large raw dv files from my old camcorder to the ATV. The files are around 5-10GB each and show up fine in nitoTV, the issue is when I click on them they say the file format is not supported. Opening them up on my Mac I can see they are 720x480 29.97 fps data rate 57.57Mbit/s (which I believe is somewhere around 7Mbps OVER the 5Mbps cap). Is there anything I can do here other than re-encoding/compressing the files?
Wow, this looks like it might be just the ticket. Quick question…
Will I still be able to play everything else as I can now? Using the traditional ATV interface? So can I still sync lower res videos etc. through iTunes, or will this Crystal card disable that and ONLY allow viewing through XBMC?
Thank you again!!![/quote]
Right, everything else will remain the same. The only drawback is the video card replaces the wifi card so the AppleTV will need to use an ethernet connection.
