Another 4.2 error
Looking for help getting 1.0 up and running. Here is the pertinent log info:
DateTime: 18/11/2011 11:33:13 Message: Connecting to AppleTV (10.0.1.2)
DateTime: 18/11/2011 11:33:14 Message: Connected successfully
DateTime: 18/11/2011 11:33:14 Message: Method SendCommand: command = mkdir /User/tmp
DateTime: 18/11/2011 11:33:14 Message: Method SendCommand: result =
DateTime: 18/11/2011 11:33:14 Message: Method SendCommandCheckResult: command = tar -C /User/tmp/ -xvf /User/tmp/payload.tar
DateTime: 18/11/2011 11:33:14 Message: command output: com.firecore.sources_1.0.deb
DateTime: 18/11/2011 11:33:14 Message: command error output: tar: Record size = 8 blocks
DateTime: 18/11/2011 11:33:14 Message: command result: 0
DateTime: 18/11/2011 11:33:14 Message: Method SendCommandCheckResult: command = dpkg -i /User/tmp/com.firecore.sources_1.0.deb
DateTime: 18/11/2011 11:33:14 Message: command error output: dpkg: status database area is locked by another process
DateTime: 18/11/2011 11:33:14 Message: command result: 2
DateTime: 18/11/2011 11:33:14 Message: Installation failed (Error: 4.2)
DateTime: 18/11/2011 11:33:14 Message: Preparing wizard page InstallationFailedPage
DateTime: 18/11/2011 11:33:14 Message: Wizard page InstallationFailedPage is activated
DateTime: 18/11/2011 11:33:16 Message: Application closed
