Anime Section in Library
Hi there,
Just a quick suggestion for anime enthusiest. As of the current infuse, Japanese anime gets grouped in with tv shows, it would be amazing if you could have an anime section. This way it would be movies, tv shows, and anime.
Thanks!
Hello,
is it possible to have Anime separate from TV shows? Maybe as a playlist? Right now if I make a playlist it shows all episodes instead of the show itself.
Thanks!
I moved your post to a currently running thread in the suggestions area requesting this feature.
You can try browsing to Library > TV Shows > By Genre > Animation
This can also be added a list or favorite for quick access.
You can like this thread to support multiple categories or libraries.
This won’t work as the normal TV Shows will still include anime as well.
