Hunter X Hunter has 148 episodes, and it seems there is no metadata available. At least, is there a way to group a shown into a collection manually? Thanks.
How do you have the files named?
They are in this format: Hunter x Hunter - 76 [1080p].mkv
Thanks.
If you follow the naming format given in the users guide it will get all the right artwork and metadata automatically for this series.
I just did a test and the Hunter X Hunter series worked great with this file structure and naming style.
Edit to add:
The above gives this
And up one level to the seasons screen
Thanks. THat’s a lot fo renaming, though!
You’re welcome!
Once you get in the habit of naming new files in compliance it’s a lot easier. I had to spend a few hours when I started using Infuse but now it’s routine.
Don’t forget that if you’re managing your files on a Mac there’s a group rename function too that may help a little.
