Hi, I’m a big fan of infuse and everything works very well.
However, I noticed that when you swipe down to open the menu while watching a movie the animation is not smooth.
https://streamable.com/hvu8q (second part is in slow mo)
Will this be fixed in infuse 6 ? Thanks.
Do you have match content and frame rate turned on? If so and the movie is running at 24fps then animations will be clunkier do to the reduced frame rate.
You’re right, I just turned it off and it was smooth.
system
closed
May 21, 2020, 1:26am
#4
