I installed Flash Black yesterday and all was working fine then today when I try to access my files via AFP I get this error. I’ve tried switching off AFP on my MBP, deleting the share details on ATV then switching it back on - but still getting the same error. Very frustrating.
I’m having the exact same problem and have had it since I did the upgrade. I haven’t had any luck fixing it. Oddly enough, the problem does not happen in XMBC, so it is a problem which apparently only affects the media browser portion.
Same here using à synology.
Since the last update of atv flash it fails to wake up my nas.
I Need to always use my iPhone or pad to wake up my nas befor atv finds it.
Hope you fix this asap
This tends to happen with my Drobo quite a bit (Gigabit connection) I’ve found that backing out and trying again once or twice almost always resolves the matter. would be great if they had a slightly longer timeout.
Frankly, this is the main reason I even use the Apple TV, much less Flash Black. I find it to be extremely buggy – especially the media player – and have no problem whatsoever using XMBC on the same Apple TV with no errors, network issues or anything else. I’m using a Synology as well, but I have no problem accessing it from literally every other device in my house.
Solaris Express, Running netatalk - worked just fine with a previous version of firecore, works fine with a plethora of macs other devices. Simply will not let me attach to my media…
DEVELOPERS! HELP, Please? I see at least two major “updates” to AFP code in this release: - “fix AFP pause after long wait” (never experienced that I don’t think…) and “Added DSI ping for better operation with AFP shares”…
My error comes back rather quickly - could this last improvement be my stumbling block?
UPDATED 2 hours later:
Issue at my end appears to be AFP 3.3 support, which to achieve, required me to upgrade netatalk from 2.1 to 2.2.2… I just did this, lit up aTV Black and was successful at connecting!! Woot woot!! All better at my end… Good luck, all!!
Personally I have found the Media Browser component of this product to be unreliable at best and I have stopped using it. And that’s the fix as well…install XMBC and you won’t have any of those network/Synology issues if you play your media through that plugin.
