+1
An idea for design would be the new song list view in Apple Music on the TVOS Beta, which has an alphabet on the right margin.
Hello
I from Germany.I hope you understand me
when will a quick alphabet search function be introduced? I have over 2000 films. Scrolling is very tedious
Thank you
Best regrads
Mario
Here is an existing thread you can like
I moved your post to the suggestions thread that munpip214 referenced.
Donāt forget that you need to click the like button on the first post in this thread to show your support for this suggestion!
Also, you may appreciate that this thread is marked as āplannedā so thereās a pretty good chance of seeing in the near future.
When sorted by name, please show all letters A-Z and make clickable. This way if I know I want to watch a file that starts with a āY,ā I can click that letter and jump down to those files instead of scrolling for ages to get there.
Allow for sorting by newest movies first (release date)
As other have suggested a list view, possibly with metadata off to the right. Would allow for much quicker scrolling.
Allow us to change these sort options within the share. This way we do not have to back out to the main menu, go into settings, change the sort options, then go back in the share.
I really would love to see this.
Itās probably one of my last of two irritations in Infuse.
Requesting a letter index similar to what the official Plex app has to quickly navigate through the movies list.
This is the only blocker that currently prevents me from using Infuse 100%.
Let me explain why.
I donāt really enjoy using my Siri remote so I usually use my LG CX remote via CEC.
While this works fine for 95% of things, there are still some apps that lack some kind of support.
Infuse is one of those apps.
How can I go from the letter A to L with a TV remote when you have a library with thousands of movies? It will take agesā¦
Thatās why Iām requesting a quick shortcut that allow us to jump to a specific letter.
Search sometimes helps, but I donāt remember the name of the movie Iām looking for much of the times, I just know it starts by that letter (I blame my age).
Hope Iām not alone in this.
Cheers.
Please, when are you going to implement this feature?? It is a very important one!!
If you notice, this suggestion is tagged as āplannedā and is listed on the upcoming features thread here.
In Plex, when you go to your TV Show or Movie library, you are able to select a letter on the right hand side which will them jump straight to TV Shows or Movies that start with that letter. This makes is much easier to navigate through large libraries.
I would love to see the same implemented into Infuse!
I moved your post to an already running thread in the suggestion forum.
Note that this feature is tagged as āplannedā so itās on the developers radar.
The alphabet location indicator has been on the upcoming list now for over a year. When it this going to be implemented.
Looking forward to having this feature. I have a pretty large library of movies and shows and itās always a pain scrolling through on an Apple TV.
Sadly Its been flagged as planned for a very long time.
Pretty sure it was flagged as upcoming at one point before moving back to just being planned.
One would think this is ālow hanging fruitā. Not sure why it keeps being pushed back.
There is some legacy code which makes this more challenging than it seems.
We need to spend some time reworking some of the views for browsing videos, and once that is done this can be added.
Hey James
In this context, you could please also finally make the scrolling smoother! Currently it is very jerky when scrolling⦠This is not the case in other tvOS appsā¦
Therefore, it would be great if you then also optimize the Scrolling when you anyway rework the UI
I think it was a mistake to close this one: Jump/Navigate through movie collection by letter
I would suggest that if I press letter āMā, the library should jump to the files/folders/videos that starts with M. I want to watch Matrix, and I donāt want to scroll and find⦠(MacOS)
It was closed because the topics were asking for the same thing.
