Firstly, great app - only got it the day before the iOS7 update, but already love it!!
I have a few suggestions, and most of them have already been raised bar one - please allow the app to download files locally to the device so we can view when we are on the plane/holidays etc. I understand remote nas access might be complicated but downloading when local would really simplify things alot! right now I have to download on my WD app then ‘Play in Infuse’ which takes quite a while if they are large files…
Just to note, the other suggestions would be (in order of preference):
Allowing to add metadata manually. A different approach could be - allow users to search theTVDB and movieDB for their file name, then pick the metadata from there which would then auto update their file in Infuse.
Add folder structure to series (although I read you guys were already on that!)
Allow rotating through all 3 zoom modes by double tapping the screen rather than the 2 - I always use the ‘stretch’ mode and thats the one not supported!
Add the scrubber bar for RW/FF
Again, thanks for your hard work, and look forward to the added features!
PS. I am a QA tester by profession so if you guys ever need an extra hand, I will be glad to help =)
