AirTunes Down after iTunes 7.7
AirTunes to ATVFlash ATVs after upgrading to iT7.7 (iphone 2.0) hangs and no longer works
Bonjour still works so iTunes SEES the ATVs but connecting hangs and fails.
Anyone having same problem? Workaround?
Thx
The airtunes issue is a conflict with the Media Cloud plugin. If you disable it, airtunes will work again.
