Airplay2 audio is not working in tvOS 11.4
Sending audio from my ATV to another device (like a second ATV) using Airplay2 in tvOS 11.4 is no longer working. Neither the volume control.
IPTV apps (based on VLC player) are also failing, could it be something related to 3rd party players? Any idea?
Thank you
Same here, I send the audio of the ATV to a pair of homepods and no sound.
Thank you
Are any apps on the Apple TV working?
Has your HomePod been updated to 11.4 yet?
Everything is updated to 11.4. Netflix and Amazon Prime work
Thanks in advance.
With two resets now is working, and I can hear the sound in the Homepods.
Strange, but glad you are up and running. :slight_smile:
Same here, James…I tried again after a reboot and now it seems to work as before.
Thank you for your concern.
