Airplay volume not working
I’m going from a iPhone 5 and a iPad 2 to an Apple TV 3. Audio doesn’t work on native Airplay. I’m playing .avi, .mkv, and .m4v. I was under the impression that this would solve all of my problems associated with playing/streaming my video media. Newest iOS is installed on all devices. Please help.
Also, some .mkv videos will not play period. I can’t figure out why or what rule I’m breaking.
I can play mkv on my ipad without any issues but when I try to airplay to Apple TV, it doesn’t play period. Are you having the same issues?
Yes to MKV issues.
I am sometimes having the same issues as you, warrior. I don’t understand. I thought this app played just about everything, at least according to the app description in the App Store. It has been nothing but trouble for me.
Sometimes MKV files won’t play at all.
Sometimes MKV files won’t play with airplay
Sometimes MKV (and other file type) files won’t play audio via Airplay.
Is your Apple TV connected to an AV receiver or just a TV?
If connected to just a TV, you may try disabling the Dolby Digital over AirPlay option which can be found in the audio playback settings menu.
[[wysiwyg_imageupload:430:]]
This seems to have fixed my mkv playback issues through airplay. Now it works but there still seems to be buffering issues every few minutes.
Will you have dolby digital over airplay fixed anytime soon?
Will be there be a fix for the buffering issue? (I don’t have any buffering issues when I convert the file to an apple format like mo4. I have an ipad mini retina with th A7 processor)
I can’t even get that far because just about every MKV won’t when I do AirPlay, which is very strange. I’ve never had an app let me play natively but wouldn’t cooperate once AirPlay to the Apple TV was activated.
What type of device is your Apple TV connected to? Dolby over AirPlay is really only useful if you’re connected to an AV receiver that can provide surround sound.
Would you mind running one of the files through ‘MediaInfo’ and sending us the specs?
MediaInfo is a free download available at: MediaInfo download | SourceForge.net
I’m running optical cable from Apple TV to a Harmon Karon AV receiver for surround sound.
Got it. One thing you may try is toggling the Apple TV’s Dolby Digital setting to On instead of Auto.
I’ll try it.
What about the buffering/playback issues?
General
Complete name                            : /Users/Stank/Downloads/complete/Homeland.S03E10.720p.HDTV.x264-IMMERSE/Homeland.S03E10.720p.HDTV.x264-IMMERSE.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 1.06 GiB
Duration                                 : 46mn 37s
Overall bit rate                         : 3 242 Kbps
Writing application                      : x264.exe
Writing library                          : mkv2rls x264-tv version built on 2011. febr. 17
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 5 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 46mn 37s
Bit rate                                 : 2 794 Kbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.126
Stream size                              : 931 MiB (86%)
Writing library                          : x264 core 140 r2377 1ca7bb9
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.05:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.10
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 46mn 37s
Bit rate mode                            : Constant
Bit rate                                 : 384 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 128 MiB (12%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
