Air Mouse Pointer not visible
I have started to use Firefox and I have enabled Air Mouse on it. The problem is that I can’t see pointer of the mouse when I try to move it across Firefox page. I can see that is there however is not visible. Anyone got similar or solution to that problem?
I’m also having this issue.
It would be great to be able to see the pointer, so I could maximize the window and navigate through pages. I can’t find a ‘tab’ function on any of the keyboard layouts either, so that also makes things a little difficult when there’s no visible pointer.
