Agonising death of Infuse 6
While Infuse 5 has it’s problems, where biggest for me was sudden amnesia, I never expected Infuse 6 to die on me in agony.
I am using Infuse Pro 6.0.2 (2519) subscription on new ATV (the original one, bought a long time ago when they just come out, but that is not important since I got the same issue on ATV4k)
First thing I did after the upgrade to version 6 was to disable iCloud sync because I don’t want to fill it with an unknown amount of random data. I did get disappointed, that while Infuse 5 shared favourite folders between multiple ATV devices and not shared watched marks, Infuse 6 did not share that even favourite folders, but this is not about that.
First thing I noticed in Infuse 6 is that every time I open any folder I need to look for a few minutes at the spinning wheel, that was not an issue in Infuse 5. Then, when I tried to watch multiple 1080p (around1.5GB) 25 min episodes in a row, each episode incrementally started with a spinning wheel, and around 4th episode it was about 5 minutes of spinning (hence the agony). And to top all that yesterday all connections to my folders died completely with “An error occurred” text after few minutes of spinning wheel no matter what folder I try to open from previously added to favourites or if I try to add something new.
All my files stored on QNAP NAS that is in the same local network and I have the same issues with both NAS I have. I connect to my NAS via FTP.
To contrast, I have no problems playing any files in VLC on ATV, everything open instantly and plays fine, so it is not an issue with my storage, but instead with Infuse 6. I hope future patches will sort this out, but for now, being an Alpha tester for a buggy application, and paying for such experience is not in my plans.
This sounds like an issue with your setup and is definitely not working as designed . Can you send in Diagnose Information (Setting → Scroll all the way down) and post code here.
Just to test, can you try connecting your share via SMB ?
Code from diagnostics - Z88XF
As for SMB, it seems that it works fine. I did use only FTP for the last few years with no issues, will switch to SMB now.
Thanks.
Sorry for the trouble, but thanks for the report.
We’re looking into a few other situations where FTP isn’t working quite right, and hope to have a fix soon.
If everything is working via SMB, you can continue using that though.
