Hi there! I can't get aTV Flash running on my second ATV 1st gen :-(
After Reset and Update to 3.0.2 and testing, if internet connection is stable i installed the latest version of aTV Flash via USB, which works fine.
Before installing any extras i took a look at install extras: nothing there to install...
So i resetted atv again, re-formatted the stick, updated to 3.0.2 and tried again --> same negative result :-(
when i try to install extras the menue is empty and i get only the message that an error occurs.
next try was to install the smart installer via maintenance/settings first. DL 10.4.9 Combo update succeded. installation works with three errors:
kextload: kext doesn't have all dependencies
kextload: can't generate internal dependency graph for /System/Library/Extensions/IODVDStorageFamily.kext
nitoHelper[191] Bluetooth.prefPane install failure nitoHelper[191] Bluetooth.menu install failure
still nothing to install after all :-)
Last try was to install Perian, mplay codec, Flash (hint:CoreAudioKit missing) and CommonMediaPlayer.
And still nothing to install in install/extras :-( :-(
Any suggestions?
THX
