Back to the question, due to 200 items each pull from Emby server, for a 200k server, it costs more than 1 hour, so i have to keep infuse in the front and keep iphone screen awake.
If I open another application, it will interrupt loading index by Infuse because it is in the background.
Hi im also having the same issue on Apple Tv 4k 2021 with loading a 380k remote Emby library Infuse takes more or less 3h to scan the library at first sync (after a fresh install) but even though it is a long time it will be Ok if it weren’t for the fact that every time the you close the app and reopen it even when the syncing is finished scanning, Infuse Re-start the library sync again (new items added frequently to the emby server) and it las 3h again at that point i just start crying and the time go faster :).
Is there any solution for this or will the new beta solve this issue.? thnx
Do you use the 32gb model or the 64gb model apple tv? If I remember correctly, you need more than 10gb free space otherwise tvos will start cleaning procedures which can potentially affect local library syncs. If this doesnt apply to you, try closing all other apps, disabling background refresh for all apps but infuse, deleting infuse, power cycling, reinstalling infuse, resyncing.
Thxs for the reply I have the 64gb version with only apple apps installed, i deleted all the bloatware
I did turned off background refresh for the only app that had it on (podcasts) and left only infuse On.I have deleted infuse many times and did all kind on reinstall even reset the ATv to factori and reinstall.
i have done all the things that you suggested numerous times with the same results. Tried metadata fetching on off with fries played with all settings i though could benefit this issue and nothing
Im writing here because im out of ideas wondering if some one had Infuse 7 with more or less 300k items remote library working correctly.
Every resync is 2-3h not only the initial sync
Hello, I have the same issue after I added emby film more than 3179, and it start really slowly , I need wait more than 10 minutes after I can play some movie before the Sync ended on My Apple TV 4k , Please help Solved this problem, Infuse is my favourite app , Thanks. and I also Ask for the beta test
I canceled my subscription because it was so slow to load my emby content. I came back to infuse today to try again but it still takes hours to load content from a remote emby server. Am I doing something wrong here?
