Yes, I have InfuseSync installed, probably because I have hundreds of thousands of videos in my media library. It takes a long time to load the content of the home page after infuse starts. It also takes a long time to open the list of all TV shows and the list of all movies.
Dang, even if those were half hour tv shows that’d still be over seven and a half years of straight watching. Dial in an occasional pause for the cause and your looking at ten years of continuous viewing.
I’m wondering if your seeing the results of the Apple TV or iOS device clearing out some of Infuses data to make room for another app or system needs frequently.
After it gets loaded what does the Metadata total in the settings screen say?
When you go to Settings (the gear icon) then General at the bottom is “Metadata” with a total bytes used by Infuse. What is this number after you get it all loaded?
Got the same issue here. Can’t even play a media file properly after adding a huge library and it says “errors playing content ”We would appreciate it if you could fix this at your earliest convenience.
Agree. This problem has been a while. Every time when I add a new remote Emby service, it needs hours to sync the data, and any interruption will block the process. Very painful.
